Question on Scanner Dimensions
- JJSoCrazy
Hi, I have a 2005 Chevy Malibu Maxx, and I was wondering the dimensions of a scanner to put in the front of the car. If anyone could help me out, it would be appreciated!
Thanks!
Thanks!
- pbryant_knight
you can get a variety of different scanners with different dimensions.
What i'd suggest is to get one of the cheap ones you can find on e-bay or most good motoring shops with dual bars, so you can use 1 or 2 bars depending on the size of your grille, and if it's too small you can make a seperate lens from red clear perspex
Peter
Peter
One Man Can Make A Replica
- pbryant_knight
- JJSoCrazy
Thanks guys, do you mean this type because I think it is really cheap looking:
http://cgi.ebay.com/Knightrider-knight- ... dZViewItem
How about this, would it work?:
http://cgi.ebay.com/FUTURISTIC-FLASHING ... dZViewItem
- pbryant_knight
It looks cheap from the box but the LED output isn't bad, its about the same if not brighter than the second as when the bars are together there's 2 led's per square inch instead of one
The second one is a JC Whitney which i currently have in my replica and i doub't very much it would fit in your grille.I had the cheaper one in my last replica and there's not much difference. i made my own lens for both so they fit under the TA hood perfectly.
peter
peter
