hey guys, i am currently studying in Dubai and found this on a bidding site located here. i will be getting it in about 5-6 days. can any of u tell me whether it is worth buying....
thx
        Knight
Knight Rider - KITT - Plans - Schematics and Guide - 95 pages
 Here is your chance to get a peek into Knight Industries Two Thousand's schematics.
This manual was originally published in the early 90's from one of the first suppliers of KITT and KARR replicas.
You will find detailed schematics of:
- scanning lights controller
- high power interface
- 4-step sequencer
- bar graph fuel level meter
- bar graph oil pressure meter
- bar graph voltmeter
- digital odometer
- voice modulator display (voicebox)
- digital and bar graph speedometer
- digital and bar graph tachometer
- bar graph water temperature meter
- dummy LED displays
The following subjects are also briefly discussed in the manual:
- adding sounds
- strobe lights
- accelerometer (G-force meter)
- voice kits
- bar graph odometer
From the Engineer who helped hundreds of Knight Rider fans to turn their conversion project dream into reality.
The manual is divided into 4 sections, each covering a different stage of the conversion. Every circuit has been designed, assembled and tested by the author. Pictures of the exact speedometer and tachometer display boards covered by the manual can be seen at http://www.jupitere.com/k200/discontinued
Despite having been published about 10 years ago, the information contained in the manual is still highly valuable today and constitute the basis for current production offered at Jupiter Electronics.
Each circuit is described in details, including operation theory with emphasis on the practical side, helping you in the best and easiest way to achieve a rewarding project - from getting the parts to final installation.
Covers the electronics only, not the plastic or fiberglass components fabrication.
Printed circuit board patterns are reproduced in the manual.
Minimum knowledge of electronics is required to assemble the boards. A useful reference if you already own a replica.
Please review the desion carefully before bidding. Does not cover the redesigned electronics featured on http://www.jupitere.com.
Complete title is Building your digital dashboard - Vol.3: The Knight Project
Knight Rider is also known as K2000, El Auto Fantastico, Supercar or Knightrider in some countries.
95 pages
spiral bound for convenience
clear schematics
color pictures
originally published in 1993
						Found This on a UAE Bidding site - KITT - Plans
- unknownknight7557
