KITT's specs
nicholasartz
KITT's specs
does anyone have a list or made a list of KITT specs and specal features. I have a list from the tv movie, I am looking for a the information I can find on The Series KITT.
- PHOENIXZERO
Re: KITT's specs
The only list out there is the BS one put up by Popular Mechanics before the premiere that they made from a conversation with a producer (if I remember correctly) and they took his joking as fact..
The new and again improved evil's advertisement is currently too long and too badass to display here. But let's just say that with now 50% more evil, this **** is great!
Re: KITT's specs
I think I got this from Joe Huth's site many years ago.
KNIGHT RIDER: A GUIDE TO K.I.T.T.'s FUNCTIONS
c. 1997-2000 by Joe Huth
Aim Laser- This manually aims KITT's laser in the event that the computer can't do it.
Air Vac.- This creates a vacuum inside of KITT, mainly used to clear smoke out.
Anamorphic Analyzer- KITT can determine what caused damage. (ex. bulletholes)
Anamorphic Equalizer- see above entry.
Anharmonic Synthesizer- KITT can imitate any sound using this.
Arm Laser- This manually arms KITT's laser in the event that the computer can't do it.
Assign- Spots on KITTs switchpod where no function is assigned. (speculation).
Aud / Vid Playback- This plays back any audio or video recorded earlier.
Aud / Vid Record- KITT records sight and sound with this.
Aud / Vid Transmit- Used to talk over PA systems or speakers.
Audio Bank- A directory of KITT's sounds and audio messages.
Audio Playback- Plays back any audio recorded earlier.
Auto Cruise- A self-propelled guidance system that allows KITT to drive by himself.
Auto Currency Dispenser- An ATM machine in KITT.
Auto Doors- Automatically opens KITT's doors.
Auto Phone- Used to call someone in KITT.
Auto Vac- KITT's self cleaning system.
Auto Windows- Automatically puts down the windows.
Auto-Roof Left- Opens the left t-top.
Auto-Roof Right- Opens the right t-top.
Blood Analyzer- KITT can detect foreign elements in the blood stream and determine blood pressure.
Boost 1- This allows KITT to gain a blast of horizontal speed.
Boost 2- A less powerful form of turbo boost.
Boost 3- More powerful than Boost 2, but less than turbo boost.
Brite- Turns on the high beam headlights.
C Mode- KITT's convertible mode.
Cancel- Used to cancel an ejection.
Chemical Analyzer- KITT can determine the composition and origin of any substance placed in here.
CO2- Fire extinguisher.
Comprehensive Configuration Analyzer- Analyzes a vehicles or buildings weak spots.
Eject Left- Ejects the driver out of the car.
Eject Right- Ejects the passenger out of the car.
Electrical Generation Mode- No radar returns.
Electromagnetic Field Disruptor- This disrupts electrical fields. (Radar, bugs, radio signals, tracking devices)
Electromagnetic Field Generator- This creates electrical fields. (Power boxes, circuit breakers)
Emergency Braking System- Used to come to a complete stop after SPM.
Evade- KITT goes around in circles.
Fire- see Flame Thrower.
Flame Thrower- Shoots a fire chain out of KITT's rear turbo boosters.
Geological Analyzer- This allows KITT to scan land formations.
Graphic Translator- Can recreate an image from a verbal description.
Ground-Air Surveillance- KITT can monitor any air activity.
Grappling Hook- A metal spike with a hook at the end.
High Tensile Reflectors- Special shields that can deflect a laser.
High Traction Drop Downs- The predessor to Traction Spikes, the back end raises up to allow for an easy climb up steep terrain.
Homing Device- A tracking device inside of KITT that the Foundation uses to track him.
Homing Signal- The signal emitted from the Homing Device
Hydrolic Lift- Used in conjunction with Rapid Cycle, it raises KITT up.
Image- This activates the Infrared Tracking Scope.
Infraray- An enhanced version of the x-ray that utilizes infrared for greater accuracy.
Infrared- see Infrared Tracking Scope.
Infrared Tracking Scope- An enhanced version of the Tracking Scope that uses infrared to scan. Range: 10 miles.
Laser- KITT is equipped with a laser power pack. (not kept hooked up)
LIC- Lic plate was called this in seasons 3-4.
Lic Plate- KITT can flip his license plate to read "KNI 667"
Manual Override- This transfers all computer controls to Michael.
Metal Scan- A special scanner designed to scan metal
Micro Jam- This blocks the electrical system in any mechanical device.
Microlock- Mainly used to lock braking systems on cars.
Micropulse- This sends out a signal to an object in KITT's scanning range and activates it.
Microwave Ignition Sensor- K.I.T.T. has the ability to activate other engines.
Microwave Jammer- see Micro Jam.
Missile- KITT can shoot a small missile out from under his bumper.
Normal Cruise- All navigational controls are used by the driver.
Oil- KITT can spray a thin layer of oil behind him to wipe out any car behind them.
Oil Jets- see Oil, Oil Slick.
Oil Slick- The same as "Oil", but it was called this in season 3 and 4.
Olfactory Scan- KITT's "sense of smell".
Oxygen- This oxygenates the interior of KITT.
Parachute- A parachute can extend out of KITT's roof in case you happen to fall off a cliff.
Passive Laser Restraint System- KITT's seatbelts. Harmless lasers hold the occupant in the seat.
Phone Tap- Used to tap into any phone conversation.
Police / Radio Frequency- Used to monitor criminal activity.
Polyphonic Synthesizer- KITT can create music using this.
Power- This puts KITT from standby to full power mode.
Printer- Used to create hard copies of anything on the monitor.
Protect- This automatically puts up KITT's windows and activates the Passive Laser Restraint System.
Pursuit- This activates KITT's boosters to give him a burst of speed.
Pyroclastic Lamination- Maintains cool body temperature in extreme heat.
Radar- The name speaks for itself.
Range- This sets the range for the radar.
Rapid Cycle- Used in conjunction with Hydrolic Lift, it creates a bouncing effect to shake debris off of KITT.
Record- This records just audio.
Retro-Rockets- Another way to stop KITT in a matter of seconds.
Reverse Turbo Boost- The same as turbo boost, only in reverse.
Rocket Boost- It has been seen as another way to turbo boost.
Rocket Fire- This can either shoot a rocket or a magnesium flare.
Security Alert- Alerts Michael to danger ahead.
Self Diagnostic Analyzer- A self-sheck program for KITT when he is injured.
Silent Mode- This makes KITT's engine virtually noiseless.
Ski Mode- To fit through tight spots, KITT can travel on his two side wheels.
Smoke Release- A smoke screen that is emitted through KITT's exhaust.
Spectro-Graph- can analize an object's mineral, metal, and gas content by analyzing light bouncing off or being emitted by the object.
Speech Synthesis Module- allows some one to talk and have KITT change their voice to sound like someone else. Used only for telephone conversations.
Sub-Zero- This immediately decreases the temperature in KITT to zero degrees.
Super Pursuit Mode- When activated, KITT transforms into a more aerodynamic car to handle speeds of 300+ miles per hour.
Surveillance Lock- This locks a car into KITT's tracking scope.
Surveillance Mode- This puts KITT on full sensor alert.
System- A protection feature which protects one of KITT's memory boards and activates an Anti-Theft device which shocks anybody that touches it with a high elctrical charge.
TDS- unknown (Possibly Theft Deterrant System?)
Tear Gas- From his smoke emitter's KITT can release tear gas.
Telephone Monitor- This unpauses the Telephone Tap.
Telephone Tap- The same as Phone Tap
Thermo Dynamic Generator- This pops the tires on a fleeing car.
Third Stage Aquatic Synthesizer- This allows KITT to ride on water.
Tinted Windows- This tints KITT's windows.
Tracking Scope- This locks on to a certain car so Michael can track it.
Traction Spikes- When activated, spikes extend from the tired to allow easy climbing of steep terrain.
Traffic Control System- KITT can control traffic lights.
Trajectory Guidance System- This launches K.I.T.T. to anywhere within a 90 degree arc.
Trunk Lid- This opens KITT's trunk.
Turbo Boost- KITT's best known function, this boosts KITT into the air to jump over obstacles.
Ultra Phonic Synthesizer- Detects heavy metal equipment and body health.
Ultra Scan- A more intricate level of a regular scan.
Ultramagnesium Charges - Used to detour a heat seaking missile.
Ultrasonic Frequency- Can be used for anything from jamming radio frequency to calling off dogs.
Voice Analyzer- KITT can detect fear or if someone is lying by analyzing their voices.
Voice Projection- This projects KITT's voice over a speaker.
Voice Synthesizer- KITT can mimic anyone's voice with this.
Voltage Deduction Coil- Used to increase or decrease electrical current in something. Located under front bumper.
Winch- This retracts the grappling hook.
X-Ray- Scans someone's bones.
Zoom-In- Used to zoom in on a picture on the monitor.
