Going beyond the Ordinary...
ivirscar
Post by ivirscar » Sun Jun 05, 2005 2:36 pm
A sneak peek at the next generation of lightbars 8)
This next generation of scanner bars will be available from Lectric Enterprises VERY SOON and I am working really hard to bring the price of this marvelous wonder DOWN LOWER than my current. The prototype here is being tested with a high tech ultra clear rubber which will completely seal the lightbay area to a point that it can be submerged in water.
This bar is equipped with 2 ultra high power LEDs with 120 degree angle perfectly suited for this application and the circuit is current limited so it cannot be "burned out" by accident. The components are encased under the small circuit board which houses the LEDs so all of the system is protected from the elements! I've had questions in the past about whether you can take my current bars thru a carwash or not, well this one, you will be able to take it scuba diving!
Here is a shot looking directly at it in the drink!
This next series of shots include:
Top left... A shot outta the drink with the refractor lens removed.
Bottom left... Same shot with it on.
Top right... A shot from above in the drink.
Bottom right... Same shot with it on.
Don't know if ya'll notice or not but this is a prototype of ONE lightbay constructed as if it were all eight! So I do not have a full scannerbar built in this fashon...YET. ;) Also, it will incorporate the red lens as usual, it was only removed (not pictured here) for clarity. These bars will be the ULTIMATE in LIFETIME lasting products... As always, UNMATCHED by the competetion. :wink:
Brenon
