1: decals, does the kit just come with the KNIGHT plate on the back or do they give you any decals for say the gauges on the dash?
2: the wheels, are the 'bowling ball' hubcaps separate from the main 'rim'?
3: does the model have wheels that you can pose the fronts in a to the left or the right position?
4: the t tops can they be removed, I saw a scan of the manual and it shows you puting them on but are they individual and can they be taken back off (like on the AMT car).
4: underside, does the model have stuff like an exhaust system (I know these kits have no engine mainly cause of the circuit board that controls the scanner effect) or is it molded in detail you have to paint.
5: the pop up lights to the swivel up or is it a deal where you choose if you want them in the up or down position (I have a Revell 83 Trans Am kit that has the option for up or down but not back and forth)?
6 :final question, is the body shell 'painted' or is it just molded in glossy black plastic, I mean could you get away with not painting it, I know I could if I wanted too, I just do not always have the time or space to do so, having it in a glossy black would save me a lot of time and headaches (mainly from spray paint fumes
Dave
